Contributor
Port forwarding does not work...?
Hello ---
I am trying to enable an inbound connection to a web server running on my home PC (Apache Tomcat).  This was working before;  something has changed.  After reading some things on the forum, it seemed likely that the router firmware (DSL2640R) might be the problem... I raised this issue with Support and they sent me a DSL3680.
With the new router, when I try to add port forwarding for port 80 to the local address of this PC (192.168.1.20), I get
     ERROR: FAIL TO UPDATE DUE TO... DUPLICATE PORT NUMBER !
This did not occur with the 2640R.  So I tried bringing up a web server on port 8080, and port-forward to this.  That worked locally;  i.e. I was able to access the website on this PC at http://127.0.0.1:8080 and I could access it from other machines on the network at http://192.168.1.20:8080, so I am thinking I don't have a firewall problem.  But coming in externally,
  • When I specify the address with :8080, the request times out.
  • When I skip the port and just try to hit the IP address directly, I now get a 403 Forbidden, saying I don't have access to /UI on the server (remote management redirect?).
Any ideas?
--- Dan
Valued Contributor
Re: Port forwarding does not work...?
Have you confirmed the port is open correctly?
http://canyouseeme.org/
Will be able to tell you.
Microsoft Certified IT Professional
Comp TIA A+, N+ | ZyXEL Certified Network Engineer.
Broadband Stats @ stats.bish.pro
Topics: 0
Kudos: 1,525
Om most of the newer talk talk routers you have to set up a seperate VLAN (virtual LAN, sometimes called a virtual server in some routers) for the web server for it to be reachable from the internet at all.
This also solves the problem that port 80 is used internally by the router for its own config pages by default, hence your error message.
Contributor
I'm tryin to port forward other ports on the Talktalk DSL-3680 but also getting the following error message:
Setting inputted into the portforwarding menu are:
  • IP address: selected one in the active dropdown list
  • Protocol type: All
  • Public start port: 8621
  • Public end port: 8621
  • Connection: PVC0 (only choice)
 I've tried various other combinations of ports:
30000-30000
30000-31000
8600-8700
8000-9000
All come back with the same error...
What am I doing wrong?
Topics: 0
Kudos: 1,525
[ Edited ]
Welcome to the forum
That router should be the same as the 2680 in set up;
http://portforward.com/english/routers/port_forwarding/Dlink/DSL-2680/
regards
Fred
