Search instead for
TT D-Link DSL-2640R modem to Linksys Router
Occasional Contributor
I'd like to get some clarification from other posts here on a similar subject, please.
I have a D-Link DSL-2640R Modem Router and want it use a Linksys EA6700 router.
On the D-Link interface, under the ‘Manual ADSL Connection Setup’ I believe I have to set the connection to ‘BRIDGE MODE’, under Wireless Set-up untick the ‘Enable Wireless’ and LAN Setup untick the ‘Enable DHCP Server’.
As the D-Link DSL-2640R has no WAN port at the back, the only option is to connect to the Linksys from the LAN port. Is this all I have to do?
Do I need to make any changes under the PPOE/PPOA Internet Connection Type window? Somewhere I read that I should have PPPoA as this is what TalkTalk uses, but if I set the D-Link to Bridge Mode then should I make changes to the connection type (currently PPPoA VC-Mux).
Thanks you.
