Trusted Contributor
Wireless bridge
Is it possible to set up a purely wireless bridge between any 2 TT supplied routers? (upstairs +downstairs). Have a spare one hence the thought. ( Want to have upstairs pc use the downstairs internet connection without any wires or homeplugs). WHich routers might be compatible here?
If so, any ideas how?
Trusted Contributor
Re: Wireless bridge
they would both have to support WDS and well ya would lose signal as would half (i think) best thing to do if possible is what i have done and connect them together via ethernet cable.
Re: Wireless bridge
well the only way to do this would be WDS this is limited to G speed wireless and only supports WEP encryption that can be broken in under a minute
and TT router do not support WDS the easyer ist way would be to use a wifi adapter for the computer unless there some reason why you cant use w-fi?
Don't forget to add your phone number to your forum profile
Valued Contributor
Re: Wireless bridge
Did anyone mention WDS?Unsure / Mellow / Droollol
Trusted Contributor
Re: Wireless bridge
think i mighta done yep, but think it got overlooked Smiley Very HappySmiley Very HappySmiley Very Happy
Valued Contributor
Re: Wireless bridge
OK, just in case .............. both routers need to have WDS capability.Cool / Roll Eyes (Sarcastic)
Trusted Contributor
Re: Wireless bridge
The only reason is I dont want to spend any money, (if I can help it ) in having to buy a PCI or USb adapter.
Super Contributor
Re: Wireless bridge
MD will sub you if you ask him nicely - he has plenty WinkSmiley Very Happy
Trusted Contributor
Re: Wireless bridge
maybe i have , maybe i havent but whatever i do have is ov no concern to u or any1 else for that matter Smiley Very Happy
Trusted Contributor
Re: Wireless bridge
Spare me some, Mark, please !
Valued Contributor
Re: Wireless bridge
mark if you leave some in a brown envelope under your seat at the x factor finals on the Saturday i will collect it on the Sunday.
sorted, that saves the postage. Smiley Very HappySmiley Very Happy lollol
barney's rabbit suki dug me my new home, and its lovely and warm.
"If we ever need a new CM then baz134dog would be my choice"
Be nice to your kids: they'll choose your nursing home.
Trusted Contributor
Re: Wireless bridge
ok ill pm u what seat i was sitting in on saturday Smiley Very Happy
