Frequent Visitor
How do I connect a USB hard drive to my TalkTalk Router and use it over my network
I have a Maxtor usb hard drive and would like to connect it to my TalkTalk router and use it on my network.
What do I need to do so that this drive is available to all computers on the network?
Mickhutch
Trusted Contributor
Re: How do I connect a USB hard drive to my TalkTalk Router and use it over my network
Perhaps this link may answer some of your question.
https://www.google.co.uk/url?q=http://techchannel.radioshack.com/connect-usb-external-hard-drive-wir...
Cheers
Donny
Diligentia maximum etiam mediocris ingeni subsidium (Seneca)
Dont let your arrogance reach your fingertips
Super Contributor
Hi and welcome mickhutch
You will need to enable and setup SAMBA on your router.  See the following thread for the hg533, I would imaging that other talktalk routers will be similar
http://www.talktalkmembers.com/t5/TalkTalk-Labs-Trials/SAMBA-setup-instructions/td-p/727002
Hope this helps
