Trusted Contributor
tony61
Founder
how to remove call divert
hope someone can help i was having problems with my phone not working and when i contacted talktalk they told me to give an alternate number till the problem was sorted now it has been sorted my calls are still being diverted and i dont know how to get it back to normal any help would be appreciated thanks
Super Contributor
barney
Founder
Re: how to remove call divert
Hi tony61:smileyhappy:
The forum staff (OCE) should be able to assist you with this when they are back online. In the meantime you may find this TT help artice in relation to setting up and cancelling call divert of some use: help.talktalk.co.uk/app/answers/detail/a_id/1562/kw/divert/r_id/113152
My regards
Barney
Trusted Contributor
tony61
Founder
thanks Barney got it sorted :smileyvery-happy: great forum help is never too far away
OCE_Ady
Topics: 0
Kudos: 573
Solutions: 291
Founder
Hi tony61,
glad Barney was able to get you sorted.
