Frequent Contributor
Can't Access Router by IP
I can't access the Huawei 533 modem router by using the IP address anymore.
When I type 192.168.1.1 I just get "cannot display web page".
It alway has worked OK, but now I can't get in to change the wifi password.
O/S = Windows 7 Ultimate 64 bit with SP1.
Thanks for any assistance you may be able to offer,
~Mike~
Topics: 90
Kudos: 1,534
Re: Can't Access Router by IP
Clear the browser cache and history
If no better try different browser
no better? do a factory reset on the router;
help2.talktalk.co.uk/broadband-wireless/how-do-i-reset-my-talktalk-router-back-factory-defaults
regards
regards
Cheers Fred,
I am a little concerned about a hard reset as I am not sure If I still have my username and password.
anything will work as the user and password for allmost everybody nowadays
but if you could try typing ipconfig in to command prompt look for you default gateway this should be the ip of your router
I Know the IP address. But when I type it in any browser I get the "cannot display web page" error. This is a fault where the router will not show the UI.
I have just read elsewhere on the forum that TT have just carried out an automatic Firmware update for these routers and is causing this problem.
Topics: 90
Kudos: 1,534
and a factory reset will cure it if that is the case.
router settings;
help2.talktalk.co.uk/broadband-wireless/talktalk-router-settings
use anything you want for wireless name/password
try adding :8080 to the ed of the ip see if that works doubtfully but worth a quick tru
Regular Contributor
probably easier just to reset the router
the router will then be accessible via the 192.168.1.1 ip address
after this you can configure your router as you had it previously, if you changed anything (SSID, password, etc)
router settings;
Thanks Fred,
I shall have a look around for my broadband password and give it a go.
router settings;
I Reset the modem router last night and it retained the username and password.
The Setup pages are now available and back to normal.
Thanks for the advice. Greatly appreciated. Smile
Regards, ~Mike~
Topics: 48
Kudos: 1,720
Solutions: 784
Hi mikerg
Let us know if you need any further assistance.
