New Contributor
DNS server not responding
Sometimes our wireless router works fine, but occasionally (normally when more people are connected to the network) it repeatedly drops the internet connection, although the LAN and DSL lights are on. We are all still connected to the wireless network but the router is not connecting to the internet (light is red on the router itself and windows reports that DNS servers are not responding).
Working through Talk Talk’s suggestions, I have tried connecting an ethernet cable to the router to establish an internet connection, which was a temporary fix but it seems to be more than this. I have also changed the DNS servers on the router page from automatic look up to open DNS servers or Google DNS servers and back to automatic, none of these changes have made any difference to the problem. Essentially the problem seems to be with the router – either hardware or settings, or some problem on TalkTalk’s end between the router and the internet.
I am unsure why it works fine for weeks and then goes wrong! Does anyone have any ideas please?
Unsure / Mellow / Drool
Topics: 89
Kudos: 1,531
Re: DNS server not responding
Welcome to the forum
If the light goes red you are losing synch with the talk talk network, you may need a profile change the OCE's will have a look when they are back next week.
In the meantime have you tried a new microfilter?
There are some self help steps here;
www.talktalkmembers.com/forums/showthread.php?t=76143
New Contributor
Thanks for the quick reply!
I have just swapped out the microfilter and will let you know if there's any improvement.
While I wait for any word from the OCEs I will start using the test socket and fill in the questionnaire.
Thanks!
New Contributor
Hi, I have now tried with a new microfilter, the problem *seems* to be diminished, although it is an intermittent fault so hard to tell with any certainty.
Since changing the microfilter over the drop in connection has only occurred twice that I have noticed and for significantly shorter times (perhaps 2 or 3 minutes) than usual.
I decided not to fill in the complete check list yet as I thought it would be useful to see if the new microfilter fixed the problem before beginning to change other variables however I will do that now given the problem does not seem completely solved, although it seems to be substantially reduced so far.
Retired
How has the connection been since your last post? Could you make sure the router is set to always on in the router settings.
Have you tested the router at the BT test socket?
Nathan
