Occasional Contributor
F-secure Subscription Key
I had to uninstall F-Secure because it disappeared from my system tray, i had it on my desktop where you could open it up and update but wouldnt run a scan Smiley Sad
I have downloaded it from 4share but its asking me for a subscription key Mad / EEK! / Confused / Frown Where do i find it?
Any help gratefully appreciated.
Super Contributor
Re: F-secure Subscription Key
Hi EastwallSmile
Did you originally download the F-Secure program from your online "My Account" (if you have one? If you did, I believe the subscription key should be available by logging into My Account under the Phone & Broadband and then Security tabs.
Barney
Originally Posted by barney
Hi EastwallSmile
Barney
I was looking at another post that you replied to and followed the instructions you gave and have now reinstalled it.
So many thanks Barney and thank you for a quick response Wink
Super Contributor
Glad you are sortedSmile
