Occasional Visitor
HD channels not showing in HD
My Youview box is working all ok but the HD channels (BBC1,2,ITV and Channel 4) are not showing in HD, i have checked in the Settings section, in the HDMI Display Settings heading it says " The current output is:NO HDMI", the box is connected to my 1080p TV via the HDMI cable, i know my tv works as i also have a PS3 which plays HD fine.  I have even tried disconnecting the PS3 to see if this was interfering with the Youview box.
Occasional Contributor
Re: HD channels not showing in HD
did you have any luck with this? I have the same issue
Topics: 1
Kudos: 3,223
Solutions: 1,228
If you navigate to Y Button > Settings > TV Signal & Quality.  Can you confirm that HDMI Display settings are set to 1080p and the Play in Hi Definition is set to 'Yes'
Just checked it's set to 1080p
Topics: 1
Kudos: 3,223
Solutions: 1,228
is the 'Play in HD option also set to 'Yes' ?
Yes it is, still not working.
Topics: 1
Kudos: 3,223
Solutions: 1,228
I would like one of our TV guys to give you a call, and possibly book out an engineer.
Please can you let me know what time is best to call. (9am to 6pm - Mon to Fri)
Please also ensure you have updated your profile to include your home phone number and alternative contact number to allow my colleagues to contact you directly.
