Occasional Contributor
HG 533 firmware update
Hello all,
I have just updated my HG533 to v1.14t. Couldn't find any release notes but that would have just ruined the fun.
The upshot is that, when it rebooted, it connected at a faster speed than it has done for a while (although this could all be incidental) & all wired & wireless units in the house function normally (not that they shouldn't).
Anyway, thought I'd let you know incase you wanted to give it a try.
SimonB
Valued Contributor
Re: HG 533 firmware update
Originally Posted by bridgebee
Hello all,
SimonB
Was that with the upgrade tool or via a trial
[ Edited ]
Sorry, should have said. This was via the upgrade option within the advanced section of the HG533.
I updated mine via wireless with no problems.
It won't look like it's doing alot, but after about 2mins it will reboot & start up in the usual manner (there is a message to this effect displayed on the screen when you click on the upgrade button).
Valued Contributor
[ Edited ]
Cheers bridgebee Smile
I'm sure everyone will get an update from OCE Nathan on his sticky Wink www.talktalkmembers.com/forums/showthread.php?t=93993
Valued Contributor
Considering Nathan wont be in work until the morning, we all have a heads up and can beat him to it Stick Out Tongue lollollol
Topics: 90
Kudos: 1,534
Well didn't get a router update email from labs, so presumably missed that one, so have done it manually instead.
I saved routers config file first and glad I did (on fibre) as it would not connect to internet until config file had been uploaded again after the firmware update.
At first glance it looked to have saved all settings after the flash, but clearly something was going on lol
Valued Contributor
No doubt you JC or Barney would discover what is going on Stick Out Tongue lollol
New Contributor
It yanks updated new software for router but printer still doesn't work Smiley SadSmiley Sad
