Trusted Contributor
Accepted Solution
Huawei HG533 Router
[ Edited ]
hey guys ive got the above router
i cant log in to it to change any settings or anything
its on the 1.14t firmware
i know thats not the newest one
but my current DSL3780 died on the weekend so i got this one from a friend
and its working
but like i said i cant access the router config at all
any ideas why ??
thanks
jason
Valued Contributor
Re: Huawei HG533 Router
hi jasonr2013
are you connected to the LAN port from your PC? type into the url 192.168.1.1 ENTER to access the router. this is the default login. user name and password is admin once you get the page up. if that doesnt help then you may have to reset the router to default to get to login. there is a little hole to put a pin in. holf for about 10 sec and release then it will turn lights out and come back on. once on you can log back in
regards
StormChaser
Trusted Contributor
hi stormchaser thanks for the reply
ive tried to access it through wireless and wired connection with 192.168.1.1
and still no joy
i did find if its not connected to the DSL i can log in then
ive not tried a factory reset yet
but im willing to try it to see if it makes a difference when its online
i was able to access my DSl-3780 with wired and wireless connections ok
could this be a firmware issue ??
thanks again
jason
Trusted Contributor
hi again stormchaser
i did a reset again
and now i can log in even when online and through wifi and lan ports
i also noticed that after the reset the router found the new firmware straight away and installed it
and to be honest it seems much better
so thanks again issue now solved
Valued Contributor
[ Edited ]
hi jasonr2013
great to hear the router is working for you. there is a setting that is ticked. under the Basic, WAN called TR069. this allows talktalk to remote the routers to upgrade the firmware too as mine was updated and i never knew. lol Smile
regards
StormChaser
