New Contributor
Re: Can I control TV volume on the Youview remote
I have the same TV in my bedroom, and have tried every code i have found on the net and on talktalk's code page and so far NONE have worked !
COME ON TALKTALK THIS NEEDS TO BE SORTED .
Retired
Hi gizmodzine,
We are unable to provide specific support for the various TV remote codes. The following help file provides a full list of the 4 digit codes for each of the manufacturer.
Can I use my TalkTalk TV remote control with my TV?
Could you please confirm what Make/Model TV you have? Some of the members maybe able to assist based upon their experience.
New Contributor
As i already said NONE of the codes work for my tv ,,,
Topics: 0
Kudos: 3,145
Solutions: 1,200
We are supplied codes by the manufactures periodically. If none of the codes supplied work specifically for your model, then you can try emailing the manufacture, or viewing the contact information for that particular manufacturer from their website,
