Contributor
Sending Emails from Android Phone and Nexus 7
[ Edited ]
I can receive emails on both devices.
Neither will send an email .
I have checked the settings following your guidance online and followed it till I am blue in the face but both devices produce messages saying that " couldn't connect to server (javax.net.ssl.SSLProtocolExceptionSmiley FrustratedSL handshake aborted - error 140770FCSmiley FrustratedSL routines etc.
Is your webpage on this subject accurate?
Any advice please?
By the way I didn't put those stupid emoticons in my text - they have appeared where I put two upper case letter S
New Contributor
sending large emails
If I try to forward a video on email it refuses saying it cannot send larger than 15000k - is there a way to do it ?
Topics: 1
Kudos: 3,309
Solutions: 1,268
Re: Sending Emails from Android Phone and Nexus 7
there is a limit to the size of an email, but you can use something such as Sky drive or Google drive.
You can upload the content to sky drive, You can then send a link via email to the content you want to share.
I use this method for all my large files.
Contributor
Topics: 1
Kudos: 3,309
Solutions: 1,268
Hi Tony,
have you followed the advice at the following link :
https://help2.talktalk.co.uk/guided-assist/setting-email-my-smartphonetablet
Contributor
[ Edited ]
Yes, as I said in my original post I have followed the online guidance ( as given in your link).
Just tried it again to see if any joy. I am getting the same "couldn't finish " message followed by a very long description of the protocol exception.
In case it might be router issue, I have tried on wifi and on data connection and get the same refusal to connect.
Incoming emails can be received with no problem.
This is very frustrating.
PS the blank post from me above was sent with text from my tablet - so some sort of connection is being made.
Topics: 17
Kudos: 1,595
Solutions: 529
Hi Tony Walls,
it seems a few people had problems setting up mail on the Nexus 7 the PC ADVISOR FORUM has some suggestions that seem to have worked.
Contributor
Thanks for replying but I am no further forward. Some of the threads from your link assume that the Nexus has a 2G or 3G connection - mine is wifi only.
I would reiterate that this problem exists on my phone and on my tablet.
The set up for outgoing emails on both devices finishes with " validating smtp settings "   then   "can't safely connect to server" then  "couldn't open connection to server "  and a very large error message. Given that both devices are producing the same outcome it seems reasonable to assume that the advertised settings are somewhat unreliable.
I am reluctant to go through the strife of changing ISP but this together with BT's free football are pushing me in that direction.
Topics: 3
Kudos: 1,356
Solutions: 246
Hi Tony Walls
Do you have an @talktalk.net email address?
What outgoing mail setting are you currently using? (please don't post any personal information)
Contributor
Chris , yes I have a TT.net account.
I have been trying to use the settings exactly as in the online guide  - port 587 etc.
The settings sometimes default to security type "none" and ports 25 or 465 without any input from me.
Topics: 3
Kudos: 1,356
Solutions: 246
Are you only sending while connected to your TalkTalk router or do you also connect to other networks?
Contributor
Chris , through TT router or via data link through TT ( including the tablet which is occasionally tethered to the android phone)
Tony
Topics: 17
Kudos: 1,595
Solutions: 529
Hi Tony,
I take it you can send via Webmail?
If you can please send me the email address/es you are trying from and the make and model of the devices along with the full error messages via Private Message.
If possible please also provide times and dates when you tried to send.
Contributor
[ Edited ]
Ady
        just tried Gmail for the first time ( don't use it generally) it works.
 My phone is a ZTE Blade 3 and as per the subject of my post I use a Nexus 7 .
If I try to send an email via TT , I get " Authentication methods aren't supported by server".
I have already given some information about the error code that I get when trying to enter the settings for outgoing TT emails.
Here is the full error information which arises when I use the TT guide
couldn't finish
(javax.net.ssl. SSLProtocolExceptionSmiley FrustratedSL handshake abortedUnsure / Mellow / Droolsl=0x12b2728:Failure in SSL library, usually a protocol error
error : 1408F10BSmiley FrustratedSL routines:
SSL3-GET-Record: wrong version number(external/openssl/ssl/s3-pktc:3450x401b7cf5:0x00000000)
I have no record of my attempts to send emails. Most of the trials have been emails to myself to see if I can get a working service.
  PS again - I see that I am getting emoticons sometimes when I enter " SS "  !!!!!!! - so there is a letter "s" replaced by an emoticon which I have not selected.
Topics: 17
Kudos: 1,595
Solutions: 529
Hi Tony,
sorry I wasn't clear in what I was asking.
Have you been able to send mail using TalkTalk webmail?
Contributor
[ Edited ]
Ady , I take it that you are meaning the AOL powered TT product.
In which case the answer is no I don't use it.
Topics: 3
Kudos: 1,356
Solutions: 246
Hi Tony,
Thanks for the update
Could you try webmail and let us know how you get on.
Could you also list the outgoing server setting that you have set on your phone and Nexus 7
Contributor
           I will try webail.
In the meantime the settings are
smtp.talktalk.net
Port 587
Security type  SSL/TLS (Accept all certificates)
Username  ......@talktalk.net
Password   as set by me
regards
Tony
Contributor
OK I tried webmail . That doesn't work.
Looked online and found this advice
"Email provided by ISPs such as TalkTalk and Virgin Media may stop you sending emails when you're not connected to the internet through your home broadband connection."
If that is correct , and why should it be , it's a poor state of affairs and in any case I can't connect even when I'm connected at home.
Topics: 17
Kudos: 1,595
Solutions: 529
Hi Tony,
that information is correct, however, if you can't send in Webmail that isn't your issue.
If you can't send in webmail there is a problem with your mail account itself and I need to raise a fault ticket for you.
To do that I need you to send me a private message containing your email address and password that you're having problems with. Please do not post this on the forum.
