Contributor
USB port on YouView box
At the back of the YouView box which has just been installed and is working well, there is a usb port. What can this port be used for? recording to an external drive or playing media from a external drive?
John
Banned
Re: USB port on YouView box
Apparently you can use it as a battery charger for a portable device, that's about it for now! Smiley Very Happy
Occasional Contributor
At present it's for engineering purposes only but who knows what a future firmware update might bring.Smiley Very Happy
Contributor
Thanks for your reply. A usb port that is kinda underwhelming....
John
Frequent Contributor
I use it to charge my PlayStation 3 controllers Smile
Contributor
Thanks for all your replies - far more helpful and informative than the webpage. Hopefully they will update the firmware so the usb port is a little more useful than charging.
Cheers
John
