Regular Contributor
YouView Plus Box Help
I have a brightspark engineer coming later in the week to replace the YouView Plus Box.
Is it possible to transfer programmes from one box to another or from the box to a HDD and then back to the new box ?
Any suggestions so my partner doen't lose part of a series of programmes she wants to keep !!!!!
Super Contributor
Re: YouView Plus Box Help
I would say its doubtful without physically removing the hard drive from your old youview box, company contents over to pc, then do reverse when new one comes.
To be honest i wouldnt bother because it may invalidate your warranty and last thing you want is for engineer to say you've tampered with the youview and wont replace it.
