Occasional Contributor
Youview on demand keeps freezing
On demand is freezing frequently - sometimes every 5 minutes or less. The picture freezes and the rotating circle appears eventaully followed by the error message. This is happening so frequently now (whether I have hd turned on or off) that its not worth using on demand. I have a sony blu ray player with BBC iplayer - this works fine in hd so it must be something wrong with Youview rather than the broadband. If it can't be fixed there is really no point me having the Youview service.
Can you resolve the problem?
Valued Contributor
Re: Youview on demand keeps freezing
What speed are you getting from your broadband connection?
8.5
Valued Contributor
What you tired re-starting your router and youview box?
No I haven't. I'll try that. As I said I have no problem watching iPlayer in HD via my sony blu ray player (I'm watching it now as I type)
Thanks for the suggestion.
Retired
Hi Cookieboy,
Are you still experiencing a problem with this? What On Demand players are affected by this issue? What error message do you get?
