Boost your Wi-Fi speed
We use the Internet every day for many different reasons: to stay in touch with friends, to work from home and so much more, however, having Wi-Fi that can't keep up is a common problem in modern households.  With as many as 14 Wi-Fi enabled devices per home, most households in the UK have outgrown a standard broadband connection. So if you've got lots of devices doing different things online, all at the same time, you might want to think about upgrading to Fibre broadband; it's the perfect choice for speed-hungry homes and includes our award-winning Wi-Fi Hub.
If you already have Fibre, it's worth remembering that there are environmental factors that can affect your speed - like your router setup, the devices you're using, problems in your local area and even your furniture.
Our Wi-Fi Hub gives you better coverage than ever before, but even the best routers can't guarantee a perfect connection in every room. If you're experiencing Wi-Fi weak spots, our Wi-Fi Extender Kit or a Wi-Fi Mesh system can help. If your Wi-Fi still feels slow, don't panic. Here’s how you can bring it back up to speed.
Just joined or upgraded?
If you're new to TalkTalk or you've just upgraded to Fibre, your line will go through a stabilisation period. This usually lasts for around 14 days and it's normal to experience varying speeds and occasional drops in your connection during this time.
router connected to electrical socketrouter connected to electrical socket
router and teklephone connect to re filtered socketrouter and teklephone connect to re filtered socket
Check your setup
Make sure you’re using a microfilter if you need one, and check to see if your router’s wires are all connected securely. If you’ve recently changed your setup, try reversing the changes to see if your speed increases.
Use your main phone socket
Make sure your router is plugged into your main phone socket, not an extension socket. It's the white plastic square built into your wall and can usually be found in your hallway or near your front door. It's bigger than any other socket in your house.
master socketsmaster sockets
Location, location, location
Ideally, your router should be upright and facing towards you when you’re using the Internet. Put it on a table or shelf – never on the floor or in a cupboard - and make sure it’s not blocked by any furniture.
Reduce signal interference
Electrical appliances like microwaves and cordless phones can disrupt Wi-Fi signals, so it’s best to keep your router away from them if you can. Try and stay close to your router when you’re using Wi-Fi, and use a Wi-Fi Extender Kit to boost signal in rooms that have Wi-Fi weak spots.
disconnect devices that you're not usingdisconnect devices that you're not using
Disconnect devices you aren't using
Having lots of devices – computers, tablets and phones - connected at once uses up more of your bandwidth. If you disconnect them from Wi-Fi when you’re not using them, it should free up your connection. You might also want to think about swapping to a package that better suits your needs.
Device limitations
Regularly updating your devices’ software and apps will help keep everything running smoothly. Remember, older devices have less capacity for high broadband speeds than newer ones. This can make your Wi-Fi feel slow regardless of the speed your router is giving out.
Laptop with a green tick on screen to show that the software is updatedLaptop with a green tick on screen to show that the software is updated
Change your wireless channel
Depending on your technical ability, you may want to try changing your wireless channel. All wireless routers broadcast Wi-Fi signals on a channel. If any of these channels get too busy – i.e. if your neighbour’s router is broadcasting on the same channel as yours – it can slow your internet down.
Leave your router switched on
We send software updates to your router throughout the day and night, so we recommend you leave it switched on. Restarting your router as a one-off can help with some connection issues; however you shouldn’t restart your router more than twice within 24 hours.
Our Wi-Fi Extender Kit
Making use of clever powerline technology, our Kit partners with your router to tackle your home’s Wi-Fi weak-spots. It uses your home’s electrical wiring to provide an easy way to extend your home’s Wi-Fi coverage, with a signal that’s fast and reliable
Buy now          Find out more
Still need help?
We have a reduced support team available at the moment, which means the wait times to speak to us may be longer than usual. Why not manage your account or get help with your services online using one of the below options
My Account
View your bills & keep tabs on your usage.
Service ​Centre
New: See how your connection is performing.
Community
Here 24/7, 365 days a year, why not post your question?
