Get the best connection from your Wi-Fi Hub
67% helpful (2/3)
Our Wi-Fi Hub is packed with the latest tech, so it should work perfectly. Still, there are lots of things that can slow your Wi-Fi down. Here's how to get the best connection from your Wi-Fi Hub.
Use your master socket
Always plug your Wi-Fi Hub into your master socket. It's a white plastic box built into your wall, usually in your hallway or near your front door. It's bigger than any other phone socket in your house.
Do you need microfilters?
If your master socket is a standard socket (with only one port on the front) then you’ll need to plug your Wi-Fi Hub in using a microfilter. You’ll also need to plug a microfilter into every other socket you’re using in your house.
Leave your Wi-Fi Hub switched on
Leave your Wi-Fi Hub switched on. We send important software updates to your Wi-Fi Hub all through the day and night. If it’s turned off, it won’t get them.
Location, location, location
Ideally, your router should be upright and facing towards you when you’re using the Internet. Put it on a table or shelf – never on the floor or in a cupboard - and make sure it’s not blocked by any furniture. This way, your Wi-Fi Hub will give out a clear, uninterrupted signal.
Reduce signal interference
Electrical appliances like microwaves, cordless phones and even remote controlled toys can disrupt Wi-Fi signals, so it’s best to keep your Wi-Fi Hub away from them if you can.
Disconnect devices you aren't using
Having lots of devices – computers, tablets and phones - connected at once uses up more of your bandwidth. If you disconnect them from Wi-Fi when you’re not using them, it should free up your connection.
Keep everything up to date
Get into the habit of regularly updating your devices’ software and apps. It will help keep everything running smoothly.
Need to speak to our team?
Our experts are here to help, select one of the following contact options:
To help us deal with your query quickly, please confirm the following information when you write to us. We will aim to respond in writing to your query in 10 days.
- Your full name
- Your TalkTalk Phone or mobile number
- Your Signature
TalkTalk Correspondence Dept
PO Box 675
Salford
M5 0NL
All letters will be sent to the primary billing address unless stated otherwise. Please also include the best way to contact you about your query, such as your contact phone number or contact address.
Call us for free on: 0345 172 0088
Make sure you have your account details to hand when you call.
Calls are free from your TalkTalk phone, our customer services team are available 8am-8pm, Technical Support 24/7 every day.
If you’re deaf, hard of hearing or speech-impaired, the Text Relay Service can be used to help you contact us, simply dial 18001 followed by 0345 1720088
