Your eero uses the latest Wi-Fi 6 technology and any devices you use will need to be compatible. It's possible some of your older devices won't support Wi-Fi 6. If you're unable to connect them, make sure they have the latest software. If you're still unable to detect your eero network, it's likely that your devices do not support Wi-Fi 6, but you can check with your device manufacturer.
We recommend updating your device's software as soon as possible, and if this doesn't help, setting your eero to Legacy Mode is a good temporary solution for getting your device online.
You may experience slower than normal speeds whilst using Legacy Mode. Once your device has been updated, we recommend you switch Legacy Mode off to get the best out of your network.
Your device should now be able to connect to your eero network. If you're still unable to connect, there may be an issue with your device and you should try resetting it.
Get help, find out more and discover useful tips on how to get the most out of your service.
