Problems with your TV picture
No ratings
Before resolving an issue you will need to decide whether you are experiencing the issue with Freeview channels or On Demand channels. Freeview channels are the channels you watch in real-time on your TalkTalk TV Box, like BBC1 and E4. These channels are delivered through your TV aerial.
On Demand channels include players, such as BBC iPlayer and ITV Hub. All catch-up TV is viewed using On Demand channels and is delivered through your broadband service.
Freeview channels
If you are having problems specific to Freeview channels such as BBC1, you can follow the steps in our troubleshooter below:
Step 1: Check all the cable connections
Check all the cable connections into the TalkTalk TV Box are secure. Check the aerial connection into the back of the TalkTalk TV Box and your HDMI/SCART cable is connected securely between your TalkTalk TV Box and TV.
Step 2: Try retuning your TalkTalk TV Box
Try re-tuning your TalkTalk TV Box. Go to Settings > TV Channels Retune Channels.
Step 3: Check your source
Check your source: You may need to select the correct source in order to watch TalkTalk TV. Your TalkTalk TV box will be connected to your TV by either an HDMI or SCART cable. If you set up your TalkTalk TV remote to control your TV: Press the AV button at the top of your TalkTalk remote control until you find the correct channel (HDMI or SCART).
If you haven't set up your TalkTalk TV remote: Press the source/input button on your TV remote and cycle through (HDMI or SCART) until you find the correct channel. If you are unable to find the source/input button, please refer to your TV manufacturer instructions.
Step 4: Check your signal quality
It may be that your signal quality is poor. To check your signal strength please see: How do I view the TV signal quality?
Step 5: Check for Planned Engineering Works
Make sure there are no engineering works in your area which may affect your service. You can do this by visiting the Digital UK website.
Step 6: Check for Electrical Interference
Recent changes in your home could cause problems with your TalkTalk TV box. Anything from the installation of new electrical devices or even building work in the local area can cause problems with your service.
Extreme weather such as heavy winds or storms can also affect your signal. Check if your roof aerial has been affected or moved by any recent severe weather.
Step 7: Restart Box
Try restarting your box. Simply hold down the power button for around 10 seconds continually, then let go. Find out more about restarting your TalkTalk TV box.
Step 8: Readjust aerial Type
Try the following depending on the aerial you have:
An internal aerial: re-positioning it to see if this resolves the issue.
A communal/shared aerial: contact your landlord or Housing Association.
An external aerial: there may be a fault with the aerial or your aerial may have moved out of position.
On Demand / TV boost channels
Step 1: Restart your router
Turn your broadband router off, leave for 10 seconds and turn it back on.
Step 2: Check cables
Check the cables into the TalkTalk TV Box are connected correctly and securely.
Step 3: Check Network Connectors
If you use Network Connectors, check they are set up correctly.
Step 4: Check your internet connection
Check your TalkTalk TV Box is connected to the internet.
Step 5: Check your broadband speed
Check your broadband speed. If you have slow speeds, this may affect your picture quality. To resolve this, follow the steps in Improve my broadband speed.
Step 6: Re-tune your channels
Try re-tuning your TalkTalk TV Box. Go to Settings > TV Channels > Retune Channels.
Can't hear sound?
Your TV will have its own internal settings for volume. You may need to use your TV remote rather than your TalkTalk remote to adjust the sound settings. Once this is set you will be able to use your TalkTalk box for volume changes after this. With a few simple steps, you can also set up your TalkTalk TV remote control to control your TV which may help your volume issue.
Mike
Hi, I’m Mike did you find my article useful?
Need to speak to our team?
Our experts are here to help, select one of the following contact options:
To help us deal with your query quickly, please confirm the following information when you write to us. We will aim to respond in writing to your query in 10 days.
- Your full name
- Your TalkTalk Phone or mobile number
- Your Signature
TalkTalk Correspondence Dept
PO Box 675
Salford
M5 0NL
All letters will be sent to the primary billing address unless stated otherwise. Please also include the best way to contact you about your query, such as your contact phone number or contact address.
Call us for free on: 0345 172 0088
Make sure you have your account details to hand when you call.
Calls are free from your TalkTalk phone, our customer services team are available 8am-8pm, Technical Support 24/7 every day. If you’re deaf, hard of hearing or speech-impaired, the Text Relay Service can be used to help you contact us, simply dial 18001 followed by 0345 1720088
