Before getting started, it's a good idea to test your username and password in webmail, to make sure they're correct. Use the forgotten password link on the website to reset your password if you're having any issues logging in. It's recommended that you have the latest OS version on your device, the below steps are for devices with Mac Mail.
Before changing your settings, we recommend that you back up your email data files on your device. For more information on how to do this check your software/app provider for instructions. Our recommendation is to use IMAP rather than POP3 settings, as this will ensure a copy of your emails is retained on our Mail server, as well as on your local device.
Check your Settings
Check out our steps on how to confirm if your email settings are correct .
adding mail account
Here are ste steps to add your mail account to your device for the first time.
If you’re still having trouble setting up your email, then for more detailed help and troubleshooting head over to the Apple site
OLDER DEVICE/IOS?
Is your device using an older version of iOS and unable to update to latest version. Check out our email setup instructions for older versions of iOS, here's some steps to check which version your device has:
- Open Settings
- Select General
- Select About and look for Software Version
ADDING A NEW ACCOUNT
- Open Settings
- Select Passwords & Accounts
- Select Add Account
- Select Other
- Add Mail Account
- On this page you need to complete the following sections:
Name - Your name needs to go in here
Email - Enter your email address
Password - This is your email password - You will see the IMAP summary page, Select Save
CHECKING THE SETTINGS OF AN EXISTING ACCOUNT
- Open Settings
- Select your email address
- Verify the Incoming Mail Server;
Host Name - mail.talktalk.net
User Name - This is your email address
If you make any changes, select Done then continue to step 5
- Verify the Outgoing Mail Server settings;
Select Outgoing Mail Server section, then SMTP, then Primary Server which is most likely called smtp.talktalk.net
Host Name - smtp.talktalk.net
Authentication - Password
Server Port - 587 - Select Done
- Select Settings
- Select Mail
- Select Accounts
- Select Other
- Select Add Mail Account
- Enter your account details
Description - A name for the account on your device - Select IMAP then enter the following server settings;
Verify the Incoming Mail Server settings;
Username - This is your email address
Password - This is your email password - Select Save
- Select Settings
- Select Mail
If you make any changes, select Done then continue to next step
Select Outgoing Mail Server then select SMTP then the name of the Primary Server which is most likely marked smtp.talktalk.net
- Select Settings
- Select Mail, Contacts, Calendars
- Select Other
Description - A name for the account on your device - Select Next
- Open Settings
Select Outgoing Mail Server, then select SMTP, then Primary Server which is most likely marked smtp.talktalk.net
APPLE SUPPORT
Head over to Apple's support site for more detailed help and troubleshooting with your device
Need some Help?
Struggling to get your email working? Why not post a question on our community. Here to help 24/7, 365 days a year.
You never know, the answer, may already be waiting for you.
Need to speak to someone?
Sorry this article didn't help...
