Your Account
How do I check my package breakdown
BenWarwick
Message 4 of 4
How do I check what I'm paying for my basic 'Faster Fibre' service? Is there a breakdown in May Account that shows you what you are paying for all the basic components of your package ie broadband, boosts and any other add-ons. I mean the unchanging details not dependent on usage.
3 REPLIES 3
Message 1 of 4
okey dokey!
GondolaVolunteer 2017-2021
 Like below to appreciate my help . . . Mark as solved + Accept as Solution
BenWarwick
Message 2 of 4
Got it, thanks. I'm just trying to weigh up the advantages of taking up a 'free' offer on the new wifi router. Will perhaps ask a couple of questions on this in my next post under a new header.
Gondola
Message 3 of 4
Hi Ben
Yes, if you select the bill online in your MyAccount and select detailed view that should give you all you need.
