Your Account
Monthly Bill not showing
BlackRockFox
Message 4 of 4
I have a problem with my July Bill not showing
I can see [Itemised Usage], click [View Bill] and it shows a blank page apart from technical issues
I have had this problem many times
3 REPLIES 3
Message 1 of 4
BlackRockFox
Message 2 of 4
Hello Arne
I tried using Edge instead and all is good now
I should have thought of that as I have had that problem before, not very often though
Thanks for the help
Arne-TalkTalk
Message 3 of 4
Hi @BlackRockFox
Sorry that you are having problems,  you could try another browser
But also can you ensure that pop up blockers are not enabled for our site, that usually fixes the problem.
Hope that helps
