2.4ghz channel keeps disconnecting
5 REPLIES 5
5ghz works great.  I have cameras and lights that only works on 2.4ghz.  I reset, it works for about 4 hours and then all the devices on the 2.4ghz stop working. I reset again and it works again.  The cycle repeats. I'm sure it's something to do with the names or channels but that's about as far as I know.  I've seen other issues similar but I'm not sure if it's the same and I don't know what to do next.  Feel if I go straight through to talk talk help they will just tell me to reset again.  Any ideas anyone please?
Hi @Scuba78 ,
There are a few things you could try to see if it is Wi-Fi interference causing the problems.
Split the SSID's on the router, this will allow you to give the 2.4GHz and 5GHz networks different names, so your Wi-Fi devices will then see those two networks separately.
Change the channels that your router broadcasts the Wi-Fi signal on, you can use free smartphone Apps like this to see what channels are being used within range of your smartphone, you can then change your router to use channels that are less congested.
If trying the above makes no difference then that may indicate a fault with your router, which the staff here would be able to help with.
Then they will hopefully be able to respond to this post within a day or two.
Hi Scuba78,
How are you getting on?
Whizz Kid
https://lizardsystems.com/wi-fi-scanner/
You could just try something like the above if you have a supported device.
I know nothing about BroadBand, but that does not stop me trying, and I am trying.
I split the names which I'm wondering if that might be some of the problem. It only started doing this in July though and I think I split them a while ago. I've updated my profile with my name etc. Thanks
Hi Scuba78
Apologies for the delay.
I've checked and your router has the latest firmware version. Please can you try factory resetting the router using the pin hole reset for ten seconds?
