4th visit from an engineer
We now have a 4th visit from an engineer, everytime they come out and say nothing is wrong, yet again, yet everytime we run the test, an engineer is booked, running out of days off to fix the issue that you are causing, have 2 lines and the other line is fine, not had an issue, so either you need to run a new line, actually fix the issue, or cancel both our lines and both full packages as your not meeting your end of the service
You are in the staff's queue for a response.
For a quicker reply can you please ensure you have your personal information up to date in your profile. Link here - https://community.talktalk.co.uk/t5/user/myprofilepage/tab/personal-profile:personal-info
Thank you
Hi leejohn02,
  • Name
  • Telephone number
  • Alternative contact number
