Anyone aboe to advice?
Dezpogfb
Message 3 of 3
Recently brought broadband from previous house but now wifi signal keeps cutting off
Message 1 of 3
Hi Dezpogfb
Keith is an absolute Guru when it comes to wifi issues, so if you can answer his questions I'm sure he can help.
If my help is needed he will also give me a prod.   If you add your phone number to your Community Profile I can also quickly check your line for any issues or errors.
Message 2 of 3
1. What make/model of router do you have (if this is a TalkTalk router, these details will be on a label on the rear or underside of it) and what firmware version is it running?
2. What is the exact status of the lights on the front of the router when this happens?
3. If you have any wired connections, are they affected in the same way as wireless ones?
