Broadband Speed Dropping
37 REPLIES 37
jaddi
I moved to Fibre broadband back in April. This increased my download speed (Router sync speed) from 3 - 3.5Mb to 16-18Mb which was great. In early June it dropped back to 15Mb and then 13Mb which was disappointing but the connection seemed pretty stable with long periods between re-syncs. Today it is down to 11.3Mb which is getting rather low. Could you please take a look and see if you can get me back up to 15Mb+. Nothing has been changed in the house since the new Fast 5364 router was installed in April.
Hi jaddi
I've completed a line test which hasn't detected any faults but I can see some re connections on the line, this can affect the sync speed.
How often do you reboot the router? Is the router currently connected at the test socket?
jaddi
Hi Debbie
Thanks for doing a test. I have just tried restarting the router from the web page and the speed has not improved.
I do not restart the router very often. Last time was on 9th of July as I had the power off for an hour for electrical work.
The router is not connected to the test socket. It is connected to the master socket via a Cat 5 cable. This has an ADSL Nation faceplate to split off the house wiring to telephones as soon as possible. On the (sadly) numerous occasions I have had issues with my long line I have found no speed improvement when connecting to the test socket.
Any chance of adjusting things to give me a bit more speed? I get the feeling that occasional transitory events slow things down and the speed never recovers. I ran at 15Mb + from the 10 April to 6 June so the line can’t be that bad most of the time.
Hi jaddi
If the connection is dropping then this will affect the speed. DLM will reduce the speed to try and stabilise the connection.
I can send a replacement router for testing, would you like me to arrange this?
jaddi
Certainly, if you think that is the way forward please go ahead.
Hi jaddi
jaddi
Hi Debbie
The new router is now running. No change to speed at all.
Before disconnecting old router sync details were:
11398Mb
30.7dB
11.8dB
1130Mb
0dB
6.8dB
and had been in sync for 3d 22h, that's since I restarted following your line tests last week.
New router is:
11398Mb
30.8dB
0dB
1141Mb
0dB
6.0dB
What do you suggest now?
Jaddi
Hi jaddi
Has the new router been connected to the test socket for at least 48hrs? We advise to allow DLM time to monitor the connection and adjust the speed with the new router connected.
jaddi
No, it only arrived yesterday and I connected it this morning at 9:40 to my usual connection place.
As previously reported: The router is not connected to the test socket. It is connected to the master socket via a Cat 5 cable. This has an ADSL Nation faceplate to split off the house wiring to telephones as soon as possible. On the (sadly) numerous occasions I have had issues with my long line I have found no speed improvement when connecting to the test socket.
If nothing improves I can move it to the test socket, but this takes a little time as involves a ladder, as I guess we will need to prove for certain that it is not my internal wiring.
Hi jaddi
If you leave the router in your current set up and post back on this thread on Thursday then I can check the connection stats again to see if the speed has increased. If the speed doesn't increase then it would be worth connecting the router at the test socket again for 48hrs.
jaddi
OK, will do
Presume I should hang on to the old router for now?
jaddi
Hi Debbie
Well its Thursday and the speed hasn't increased
11398Mb
30.80dB
11.9dB
1141Mb
0dB
6.7dB
BUT- yesterday the power tripped in the house (builders round doing work) just before 11am so router restarted. It had also rebooted it's self at 2:25 that morning for a software update.
So I guess that won't have helped the DLM? Should we just leave it another few days?
I will await your advice.
Hi jaddi
I've checked the connection stats and I can see that the sync speed hasn't increased, apologies for this.
If the connection remains stable over the next 48hrs but the speed doesn't increase then I will raise this over to our Network Team for investigation.
jaddi
OK, suggest we look again on Monday as I will be busy over the weekend. If no better, can then try in test socket for a few days if you think best before we get other's involved.
Hi jaddi
It may be worth connecting at the test socket as soon as possible as this will rule out any possible internal wiring/face plate issues.
I can then escalate this on Monday if the speed is still the same.
jaddi
Hi Debbie
That's the router in the test socket from about 14:00. It was disconnected for about a hour during the process.
Sync speed the same
11399Mb
33.5dB
13.0dB
1141Mb
0dB
6.9dB
Will monitor and liaise again on Monday at some point
Hi jaddi
Thank you. I will check the connection stats on Monday morning and post back on this thread.
jaddi
Hi Debbie
So since Thursday's move to test socket I can see two events:
19/7
11399Mb
33.4dB
12.9dB
1209Mb
0dB
6.3dB
Resync @ 00:15 – single event – Usual “The WAN DHCP client process has successfully been terminated on Vlan 36 “
@ 9:09 in sync 9h
and
22/7
15000
33.4
8.6
1201
0
6.7
Resync @ 00:30 (As per 19/7)
@ 10:32 in sync 10h
So the resync early this morning has increased the router sync speed a bit.
My actual working download speed is only about 8Mb, probably  as I am now connected via WiFi rather than LAN?
Guess you will be able to see more about what'd happened at your end.
Where now?
Jaddi
Hi jaddi
I've checked the connection stats and I can see that DLM has started to change the line profile and the speed has increased from 10.9mb to 14.3mb.
Please can you leave the router in your current set up whilst DLM is monitoring the connection, we can check to see if the speed increases any further.
