Broadband and internet fault.
3 REPLIES 3
sparkellis01
My broadband/internet stopped working last night.
I have run a Service Check and it  says there is "an issue with my broadband". I'm looking for help on how to fix this.
Screen grab of Service Check:
https://photos.app.goo.gl/9bdMT2qDRQctHrVg8
Many thanks,
Mark
Mark
OCE_Karl
I'm showing the router online at the moment, has your access been restored ?
sparkellis01
Hi Karl, it is dropping in and out. We are having periods of connectivity and then outages.
It's v challenging to stream anything, like Netflix.
Thanks,
Mark
Mark
OCE_Michelle
Morning Mark,
Sorry for the delay and thanks for confirming. I'll take another look now.
I've run a test on the line which hasn't detected a fault, however I can see re-connections on the line. Is the voice service ok with no noise on the line? Does your master socket have a test socket? If it does then would it be possible to connect the router at the test socket to see how the stability compares?
