Broadband connection keeps dropping
Hi chousden,
Thanks for confirming this and I've asked our Network Team to confirm what the next step will be. I'll keep you updated.
Hi chousden,
Our Network Team have advised that they have sent a different make and model of router for you to test. They have asked if you can let us know how the stability compares once this router is connected.
chousden
I have connected this router now and will see how it does.
chousden
I've already had one drop out at 20.36 today with the new Talktalk router.
Hi chousden,
Thanks for the update. I've re-checked the connection stats and I can see that DLM has made a change to the profile today. Please let us know how the stability and speed compares over the weekend.
chousden
This has still been disconnecting quite a lot over the weekend with the new router. Checking the logs, I can see the following disconnections:
Friday: 00:36:53, 02:33:50, 10:34:27, 12:32:17, 12:47:18
Saturday: 08:37:06, 10:33:33
Sunday: 10:34:44
Is the router situated close to other electrical devices that could be causing interference? Is your router connected directly to a wall socket or is it connected to a multi-socket electrical extension lead shared with other devices?
When you swapped the routers over did you also use the cables provided with the new router?
chousden
Hi Chris
The router isn’t near any other electrical devices and is connected directly to the wall power socket.
In terms of the phone socket it is connected to the master socket using the cabling (including the socket filter) supplied with the new router.
Nonetheless the same problem has continued while using this router as with the others.
Caspar
Hi Caspar,
If the connection is still dropping with the new router then the next step will be to arrange an engineer visit. If you'd like us to go ahead with the engineer visit
can you confirm:
I've also PM'd you to confirm some other details
Hi Caspar,
I've replied to your PM
Hi Caspar,
Our network team have taken another look at this and decided to send it for an our of hours card reset before taking any further action, this should take place tonight so can you please monitor tomorrow and let us know if there's any improvement
chousden
Thanks Chris
I will keep an eye on it for the next few days and let you know how it gets on.
chousden
Hi Chris
Unfortunately the disconnections have continued over Friday and the weekend. At the time of writing these have occurred as follows:
Friday:
02:36:50 (I presume this one was the card reset you referenced)
16:33:26
18:35:42
22:42:35
Saturday:
00:36:25
01:55:12
02:35:00
18:34:14
Sunday:
08:36:51
So unfortunately it does look like the reset hasn’t improved the stability of the connection.
Caspar
saunders1
We are having the exact same issue, we are new customers to talk talk and ever since we have had it our connection keeps dropping. We have contacted talk talk three times and the problem still persists. It makes us wish we never left our previous provider.
If anyone could help us resolve this also it would be incredibly helpful
thanks
Jenny
saunders1
thanks
Jenny
Hi Casper,
The card reset appears to have been the 01:55 connection on the 8th, could you monitor for another 24 hours and if disconnections continue can you bump the thread tomorrow and we'll pass it back to our network team for further investigation
Hi Jenny,
Can you start your own thread and we'll be happy to look into this for you 🙂
saunders1
Thankyou, I have now done this
Jenny
