Broadband died
55 REPLIES 55
All Saturday there was no broadband or dial tone just a engaged tone if you dialed my number from another phone it said it was a invalid number
Sunday the phone worked again but the internet still is not working ,when will this be fixed ?
Hi Loudkitten,
I'm sorry for the delay. The line test hasn't detected a fault and the line is currently in sync. Is the connection ok at the moment?
Thanks but it's no better it connects but it's so slow most sites time out I cannot use it on this site . I have tried two routers in the main box and both had similar results slow unusable speeds I cannot even use a speed test site because it times out
Hi Loudkitten,
Thanks for the update and I'm sorry to hear this. I've re-checked the connection stats and I can see that the SNR and sync speed are varying quite a bit.
Does your master socket have a test socket? Is the voice service still ok at the moment with no noise on the line?
The voice service seems fine now if was only on Saturday it went down I will have a go at the test socket when the builders are out the way thanks for your help.
Hi Loudkitten,
Ok thanks. Please let us know once the router is connected to the test socket and we can re-check the connection stats again to see how it compares 🙂
Things are getting worse the voice has gone to engaged tone there is no internet at all but I do have it plugged into the test socket with micro filter
If this requires a home visit I need warning because the area needs to be made ok with the builders
Hi Loudkitten
Apologies for this.
Is the voice fault (engaged tone) still present if you test with a corded handset at the test socket, with the router removed from the line?
If you dial 1571, do you receive a message to advise there are messages waiting on the line?
The continuous engaged tone has now gone and the dial tone is back,this is weird stuff all I can do is try the other router in the test socket if you want.
Hi Loudkitten
Yes please, do you have a spare router to test with? (If not then I can send a replacement)
The engaged tone fault is present at test socket I never got the chance to remove the router before the dial tone returned again and 1571 says I'm not subscribed to the service thanks for your help
Hi Loudkitten
How often is the engaged tone present? (daily)
Ive changed the router and micro filter and it's all in the test socket , after a while it managed to connect but its so slow Google search page takes about a minute to load if it don't time out. Ive only ever heard the continuous engaged tone Saturday when the troubles started and today thanks for your help
Hi Loudkitten
Your line is showing in sync at 16.8mb. Please can you run a speed test using a wired connection?
Ok I give it a go when I can borrow something with a lesd it  don't seem hopeful I've just tried three WiFi devices from about one metre away and no joy one was even a fresh install
Still got no lead but engaged line fault again zero internet and all this using different micro filter and router plugged into test socket
Since 6pm yesterday it appears to be working ok thanks. (I will probably regret saying that )
Ok, there was an outage in the exchange on Sunday, There may still be work being carried out.
Continue to monitor.
