on 02-01-2019 08:59 AM
Hope I’ve come through to the right place. I’m sure this is a peak time congestion issue. I have had many issues with the broadband over the years, been back and forth with talk talk chat support and by phone. I get no where, hoping someone here can help.
Over the last few months internet keeps dropping to a complete stop usually on weekday evenings but almost always on Sunday mornings and bank holidays. This Christmas Eve and Day and boxing day was awful connection. And again, New years eve and New Year’s Day internet was dropping again.
Background Info:
Ping and Trace when internet is relatively OK:
01/01/19, 11.28 am
Ping has started…
PING google.co.uk (216.58.210.35): 56 data bytes
64 bytes from 216.58.210.35: icmp_seq=0 ttl=54 time=26.179 ms
64 bytes from 216.58.210.35: icmp_seq=1 ttl=54 time=26.636 ms
64 bytes from 216.58.210.35: icmp_seq=2 ttl=54 time=27.878 ms
64 bytes from 216.58.210.35: icmp_seq=3 ttl=54 time=55.933 ms
--- google.co.uk ping statistics ---
4 packets transmitted, 4 packets received, 0.0% packet loss
round-trip min/avg/max/stddev = 26.179/34.157/55.933/12.588 ms
01/01/19, 11.29 am
Traceroute has started…
traceroute to www.google.co.uk (216.58.204.35), 64 hops max, 72 byte packets
1 192.168.1.1 (192.168.1.1) 1.400 ms 1.115 ms 0.992 ms
2 * * *
3 host-78-151-238-201.as13285.net (78.151.238.201) 24.299 ms 24.203 ms 27.304 ms
4 host-78-151-238-204.as13285.net (78.151.238.204) 24.262 ms 24.810 ms 24.577 ms
5 host-78-144-9-69.as13285.net (78.144.9.69) 24.549 ms 25.673 ms 25.117 ms
6 209.85.175.102 (209.85.175.102) 30.058 ms 24.629 ms 25.258 ms
7 108.170.246.129 (108.170.246.129) 25.158 ms 25.472 ms 24.264 ms
8 108.170.238.117 (108.170.238.117) 25.364 ms 24.627 ms 31.240 ms
9 lhr25s12-in-f35.1e100.net (216.58.204.35) 24.344 ms 25.314 ms 24.753 ms
______
Ping and Trace when broadband drops again about 30 mins later:
01/01/19, 11.58 am
Ping has started…
64 bytes from 216.58.210.35: icmp_seq=0 ttl=54 time=284.128 ms
64 bytes from 216.58.210.35: icmp_seq=1 ttl=54 time=197.787 ms
64 bytes from 216.58.210.35: icmp_seq=2 ttl=54 time=148.493 ms
64 bytes from 216.58.210.35: icmp_seq=3 ttl=54 time=93.720 ms
round-trip min/avg/max/stddev = 93.720/181.032/284.128/69.985 ms
01/01/19, 11.59 am
1 192.168.1.1 (192.168.1.1) 1.825 ms 1.023 ms 0.965 ms
2 * * *
3 host-78-151-238-201.as13285.net (78.151.238.201) 136.735 ms 114.942 ms 125.872 ms
4 host-78-151-238-204.as13285.net (78.151.238.204) 101.719 ms 102.153 ms 100.983 ms
5 host-78-144-9-69.as13285.net (78.144.9.69) 140.106 ms 190.573 ms 139.637 ms
6 209.85.175.102 (209.85.175.102) 152.368 ms 89.423 ms 169.505 ms
7 108.170.246.129 (108.170.246.129) 153.396 ms 114.912 ms 114.859 ms
8 108.170.238.117 (108.170.238.117) 114.447 ms 124.698 ms 114.588 ms
9 lhr25s12-in-f3.1e100.net (216.58.204.35) 51.744 ms 23.889 ms 25.135 ms
Any help/advice would be greatly appreciated. Thanks in advance
on 13-03-2019 07:26 PM
Sorry about the late reply, I've been slowly testing different routers every Sunday with different connections and always seemed to have slow broadband around those times as mentioned before.
Unfortunately, on Friday around 8pm, the internet connection dropped twice and then was dead. The phone line had a loud buzzing noise. On Saturday, after calling Talktalk support several times the phone eventually starting to drop the connection. And engineer was booked by my sister and he came out today, said there was a fault within 25m, and replaced the phone line from that master socket to the local phone line column/post.
He left and came back because one of the line tests weren't good but then everything seemed to work so he left. In the last 8 hours, the connection has reset about two or three times and around 6.30pm, with an incoming phone call the internet dropped and the light turned red. After 2 minutes or so it came back.
I don't really know what to do from here. Is this normal after installing a new line? To be frank, I'm really tired of having to deal with this. We chose Talktalk because its the cheapest option but as it stands, we just had no broadband whatsoever for four days - whatever Talktalk is charging, it's really expensive for a non working broadband.
And just as I type this, the internet dropped once again.
on 17-01-2019 10:46 AM
Hi Ant88ant
The DSL3782 router is on its way, please allow 24-48hrs for this to arrive.
on 17-01-2019 10:34 AM
Hi Debbie,
That'd be perfect thank you. Once it arrives, I'll see how it goes and come up here and update.
on 17-01-2019 10:13 AM
Hi Ant88ant
I can send the DSL3782 router to the address linked to the telephone number in your Community Profile, will this be ok?
on 17-01-2019 10:03 AM
Hi Michelle,
Yeah let's give that a go in that case. No harm in trying. What is the process for requesting the router? Thanks
on 17-01-2019 09:48 AM
Hi Ant88ant,
Ok thanks for letting me know. Would you like to try the 3782 router? As this issue is intermittent then you could keep hold of this for a while to see if the connection still drops on a Sunday.
on 17-01-2019 09:21 AM
Hi Michelle,
No, nothing like that at home. I did have the same suspicion though a few months ago and thought perhaps it might be some other device that the neighbours switch on on Sunday morning and other peak times (which would make sense since that's when they're home) that was interferring with the wifi so I swapped through the different channel settings for both frequencies and it didn't help - that was before I realised my TV would have the same issue and it's connected by ethernet cable!
on 17-01-2019 07:49 AM
Hi Ant88ant,
Just to confirm, do you have any devices set on a timer on Sunday morning or use any different equipment/devices on this day when the connection drops?
on 16-01-2019 08:36 PM
Hi Debbie, last drop was on Sunday morning, between 9ish am and around 10.30am/11am. Not quite sure when it returned but I believe it was working by 11am.
As for sending the dsl3782 - how long will i have before sending it back? The broadband usually drops at peak times only but usually on Sunday mornings.
Also, just so that I can learn, why did you suggest this router? Is there anything in particular you think is the issue with the current router/or anything I can do on my end?
on 16-01-2019 06:51 AM
Hi Ant88ant
Your connection is now showing in sync and connected for just over 2 days and 20 hours, with no drops in connection.
When did you last experience a drop in connection?
I can send a DSL3782 router for testing if you would like to test with this router?
on 15-01-2019 02:20 PM
Hi Debbie,
The current one is HG633 but the older one which I tried when the problem started many months ago is a dsl 3780. Do combination of blinking lights I described mean anything in particular?
on 15-01-2019 06:41 AM
Hi Ant88ant
Which make and model of routers have you tested with?
on 14-01-2019 06:46 PM
Hi, thanks for your reply,
I think the lights do change but they don't seem to follow a pattern. At first it seemed as if all the times the broadband dropped, the internet and wireless lights would blink in unison (and the power and broadband lights remain solid) but I've noticed now that happens even with good connection - and likewise, there have been occasions when the broadband dropped and these lights were not blinking.
on 14-01-2019 09:34 AM
Hi Ant88ant,
Thanks for running the tests. Do the lights change on the router when the connection drops. I can see a reconnection yesterday morning but that's the only one that I can see since the 1st.
on 13-01-2019 11:47 AM
Hi again, apologies about the late reply but whenever the broadband dropped, by the time I had the ethernet cable hooked up it started working again.
Yesterday I finally managed to do a ping and trace whilst the internet was slow and have run several speed checks as advised though I don’t know how many were successful.
This morning the broadband was down completely and the speed checker wouldn’t load at all. Like I said, this happens every Sunday morning without fail and during peak times on Saturday and weekdays evenings.
Here are the results:
Speed test:
Date and Time: 12/01/19 18.07
wifi off - ethernet cable
12.3mbps
Date and Time: 13/01/19 09.40
8.2 down, 0.6up, 26ms.
note - broadband was fully down, couldn't connect at all, took 15+ attempts and several modem restarts.
Date and Time: 13/01/19 10.38
— no connection at all - as expected on Sunday, every Sunday at the same time.
___________
Date and Time: 12/01/19 17.47
Ping has started…
PING google.co.uk (216.58.206.67): 56 data bytes
64 bytes from 216.58.206.67: icmp_seq=0 ttl=55 time=85.848 ms
64 bytes from 216.58.206.67: icmp_seq=1 ttl=55 time=100.313 ms
64 bytes from 216.58.206.67: icmp_seq=2 ttl=55 time=105.720 ms
64 bytes from 216.58.206.67: icmp_seq=3 ttl=55 time=166.177 ms
round-trip min/avg/max/stddev = 85.848/114.514/166.177/30.699 ms
traceroute to www.google.co.uk (216.58.198.99), 64 hops max, 72 byte packets
1 192.168.1.1 (192.168.1.1) 0.791 ms 0.544 ms 0.433 ms
2 * * *
3 host-78-151-238-201.as13285.net (78.151.238.201) 96.884 ms 123.148 ms 123.482 ms
4 host-78-151-238-204.as13285.net (78.151.238.204) 125.317 ms 111.234 ms 111.348 ms
5 host-78-144-9-69.as13285.net (78.144.9.69) 125.242 ms 125.125 ms 123.565 ms
6 209.85.175.102 (209.85.175.102) 124.314 ms 113.137 ms 123.915 ms
7 108.170.246.129 (108.170.246.129) 89.631 ms 113.093 ms 135.650 ms
8 64.233.175.155 (64.233.175.155) 113.266 ms 114.062 ms 105.416 ms
9 lhr25s07-in-f3.1e100.net (216.58.198.99) 111.431 ms 124.978 ms 138.460 ms
___________
Thanks again for your help, much appreciated.
on 02-01-2019 01:59 PM
OK thanks 🙂
on 02-01-2019 01:49 PM
Alright that makes sense, I'll post back here once I've dont the tests. Thanks
on 02-01-2019 12:14 PM
OK thanks
The last set of pings and traces show higher latency, we just need to confirm that this is repeated on a wired connection and if your throughput speeds are also dropping on our speed tester on a wired connection. we can then ask our network team to take a look
on 02-01-2019 11:59 AM
Hi Chris,
Sure thing, it might take a couple of days - I'll try and catch it when the broadband drops again. Can I just check in the mean time what we are checking for? Did the ping tests that I posted show anything specific - I can see there's a difference in the time intervals but not sure what this means exactly.
on 02-01-2019 11:26 AM
OK, thanks
Would you be able to run another set of pings and trace routes on a device connected by Ethernet cable.
Could you also run 3 sets of speed tests at different times of day on the My Account speed checker on a device connected by Ethernet cable to your router (can you try to make sure that no other devices/applications accessing the internet at the time)
