on 02-03-2019 02:32 AM
on 11-03-2019 07:50 AM
Hi Axa23,
Ok thanks for confirming this. The line is now showing in sync for almost 2 days. How has the stability been since your last post? Could you run a wired speed test so we can see how the throughput speed compares in relation to the sync speed please.
on 08-03-2019 02:07 PM
Hi, just done as requested and can confirm again that the router does not work in the test socket ( tried 2 different micro filters so not these). As mentioned before last time my internet played up it was suggested I get a split master socket ( one socket for broadband, one for phone line) which I did and speed showed a massive improvement. The engineer at the time did state that as the signal was now split at source that the designated socket was the only one that the router would work in, think this is why test socket behind faceplate not working with the router.
08-03-2019 01:16 PM - edited 08-03-2019 01:17 PM
Hi Axa23
Would it be possible to connect the router at the test socket again so I can check the connection stats? Can you connect the router using a different microfilter?
on 08-03-2019 12:53 PM
on 08-03-2019 07:09 AM
Hi Axa23,
Ok thanks for trying this. Is the router usually connected directly at the master socket? Do you have any extension sockets?
on 07-03-2019 12:38 PM
There is a test socket behind the plate, which I plugged the router into on the first weekend I initiated this thread to see if it would rectify the problem. I also used a micro filter on it at the same time. I had no internet at all using this method, as mentioned before think it might be because it is a pre filtered socket openreach MK3.
on 07-03-2019 10:42 AM
Hi Axa23
Would it be possible to post a photo of your master socket? There should be a test socket underneath the faceplate.
on 07-03-2019 10:19 AM
Unfortunately it is a pre filtered socket so I don't think that the router will work from it, tried before and no broadband at all. All a bit techie for me but sure you understand this more than I do
on 07-03-2019 10:02 AM
Hi Axa23,
Ok thanks for confirming. I can see that DLM has lowered the sync speed slightly due to a high number of errored seconds on the line. Does your master socket have a test socket?
If it does then would it be possible to connect the router at the test socket and we can try optimising the connection again to see how the sync speed compares?
on 07-03-2019 09:41 AM
on 07-03-2019 07:20 AM
Hi Axa23,
Thanks for the update. Just to confirm, are you running the speed tests wired or wireless?
on 06-03-2019 02:45 PM
Been monitoring as per request, has dropped down to 4 on a couple of occasions but think this might be the speed test program itself rather than the broadband speed itself. Most tests show between 6 or 7 but line was holding at about 8 solid for weeks before this issue so seems like a bit more tweaking to be done please
on 05-03-2019 06:56 AM
Hi Axa23
Please can you continue to monitor the connection/speed over the next 48hrs and let us know how you get on.
on 04-03-2019 06:30 PM
Thank you for your help Michelle, I have just got home from work and carried out a speed test and obtained 9 Mbps wired which I have never got in all the years with talk talk. I used the landline as well to see if the broadband would drop out and it seemed to stay steady. Can we not close this yet as I would like to monitor for a while in case the problem returns?
on 04-03-2019 08:40 AM
Hi Axa23,
Thanks for the update. I've run a test on the line which hasn't detected a fault so I've optimised the connection to try and increase the sync speed further 🙂
on 03-03-2019 04:51 PM
Hi making progress! the OCE team will pick up on this tomorrow, I'm just a mere customer mortal. But rest assured the wheels are in motion.
D
on 03-03-2019 03:36 PM
on 03-03-2019 01:47 PM
Hi Axa, none that will help, I think we will have to wait for the professional s tomorrow. They can run diagnostics etc. Good luck, I'll keep an eye on progress.
on 03-03-2019 11:50 AM
on 02-03-2019 10:44 AM
Hi Axa, don't mean to be death by 1000 questions, could you elaborate on your router, is it Sagemcom and were you using the router password rather than WiFi password to access the gui?
