Broadband keeps dropping
ryssbowh
Message 13 of 13
My broadband keeps dropping several times a day, up to 20-30 times worst days. Internet is unavailable for a minute or two and comes back.
The other person in the house is also affected, happens both on wifi and ethernet.
It's been like this for a long time, I thought it was coming from my computer but am now sure it's not.
I upgraded to Fibre 65 last November.
What can be done to pinpoint the issue ?
12 REPLIES 12
Message 1 of 13
Hi ryssbowh
No, being at the test socket just rules out any issues with the face plate or internal wiring.  I have my router at my test socket.
I've ordered a replacement router so we can rule this out. Please allow 24-48hrs for this to arrive.
ryssbowh
Message 2 of 13
@Debbie-TalkTalk  I guess we can do that, but the router is "new", was sent to me when I started the contract, less than 2 years ago.
No I haven't tried another router, I don't have one.
Is being on the test socket not an issue in itself ?
Message 3 of 13
Hi ryssbowh
Have you recently tested with a different router? Would you like me to send you a replacement router for testing so we can rule this out?
ryssbowh
Message 4 of 13
@Debbie-TalkTalk that's strange since there doesn't seem to be another socket.
It's always been like this since I moved in this flat,  about 2 years ago
Message 5 of 13
Hi ryssbowh
Thank you. Yes this appears to be the test socket.
Have you just connected the router there now or has it always been connected there?
ryssbowh
Message 6 of 13
@Debbie-TalkTalkI'm not sure but I wouldn't think so, here's a photo :
Message 7 of 13
Hi ryssbowh
I've completed a line test which has detected a potential fault.
Is the router currently connected at the test socket?
ryssbowh
Message 8 of 13
Hi @Debbie-TalkTalk
I've added my phone to my profile
Message 9 of 13
Hi ryssbowh
Please can you add your TalkTalk landline number to your Community Profile, we can then look into this further.
ryssbowh
Message 10 of 13
Thanks for your answer @Skynet_TX ,
The light doesn't do anything special.
I've run the test several times, it never shows any problem.
I don't have a phone or a test socket in the house.
ryssbowh
Message 11 of 13
Thanks for your answer @Skynet_TX,
I've run the connection test several times, doesn't show any problem.
I don't have a phone in the house, neither a test socket.
Skynet_TX
Message 12 of 13
Hi @ryssbowh,
What do the light(s) do on the router when the connection drops ?
It would be worth going to the Service Centre to run a connection test on your line, this will indicate if there is currently a fault affecting your service. You can also access this from the ‘My Account’ site.
If your master phone socket has a test socket then you could also try the router in there, that would then eliminate any of the phone wiring in your home as being a possible cause of the problem.
The TalkTalk staff on this community will be able to help, they will hopefully be able to respond to this post tomorrow.
