Broadband not working flashing orange light
Robcol
Message 17 of 17
I have been without internet all day and am struggling to get in contact with anyone who can help. My phone is working and I have changed my micro filter but this have not helped. The router is mainly flashing orange but sometimes goes white for a few seconds. Any help welcome!!!
16 REPLIES 16
Message 1 of 17
I'm struggling to connect to the router currently. The new router is on the way to make sure the current router is not at fault.
Robcol
Message 2 of 17
Thanks, I have just done this
Message 3 of 17
Hi Robcol
Can you factory reset this router using the pin hole reset for ten seconds, I can then try and connect to the router.
Robcol
Message 4 of 17
Hi, no, it’s still not working. I can see the network in my wifi list, but when I connect I get no internet. When I plug a direct line into my laptop it also says no internet. (I don’t know the history of this old box, is there a way to check its settings?)
Message 5 of 17
Hi Robcol
The line is now showing in sync. Can you connect ok now?
Robcol
Message 6 of 17
Hi Debbie, it looks physically the same as the existing router. I have plugged it into the main socket and using a new filter (basically I have swapped it over with the defective on).
it is now connected and has a white solid light
Message 7 of 17
Hi Robcol
Which make and model is it?
Is it connected at the test socket? Did you also swap over the cables and filter?
Robcol
Message 8 of 17
It is an older TalkTalk router, I did try plugging it in but it ended up with a white light but still no internet
Message 9 of 17
Hi Robcol
Is it a TT router?
If it's not then this help page should help Set up a non-TalkTalk router
Debbie 🙂
Robcol
Message 10 of 17
Thanks Debbie.
Until the new router arrives would I be able to use an old one I have or would it not be set up?
Message 11 of 17
Hi Robcol
Let us know how the connection compares with this router
Robcol
Message 12 of 17
Yes please. How quickly would it arrive?
thanks
Message 13 of 17
Hi Robcol
I've completed a line test which hasn't detected any faults.
Are you happy for me to send a replacement router for testing?
Robcol
Message 14 of 17
Thanks, I have done this
Message 15 of 17
Hi Robcol
Please can you add your name and TalkTalk landline number to your Community Profile, we can then look into this further.
Gliwmaeden2
Message 16 of 17
Professional staff will be back in the morning, @Robcol. They'll need to identify your account.
Please add your Talktalk landline number to your community forum profile details by going via your avatar/name; settings; launch profile wizard.
Your thread is in the queue for attention.
Try switching the router off for 30 minutes. It may successfully connect after that. Then leave it on for staff to test your line when they reach your thread.
