Broadband speed 6 or 7 Mbps
I see people referring to speeds of 47 ... in my dreams.
Everything is very slow and i often have to disconnect wifi and reconnect on my devices to kick start it into action ...
I've had a new router for a week - what can i do, or what should i expect of TalkTalk?
thanks
Hi @KateG64 ,
What broadband service are you on, ADSL or Fibre ?. The speeds you can get are totally dependent on the length and quality of your phone line, so everyone's potential top speed is different. When you signed up for your TalkTalk contract they would have quoted an expected speed range and guaranteed minimum speed for your line.
You could also use this site to see what speeds BT think your line could achieve, this should show the possible ADSL and VDSL (Fibre) speeds that your line could potentially provide.
If you are getting speeds well below what you expect then this may indicate that there is a fault somewhere.
It would be worth going to the Service Centre to do a test on your phone line, this will indicate if there is currently a fault on your line. You can also access this from the ‘My Account’ site.
The staff won't be around now until Monday, but they should be able to respond to this post early next week to help.
Hi KateG64
  • Name
  • Telephone number
  • Alternative contact number
