on 28-12-2022 02:13 PM
I was without broadband for five days was sent new equipment but no deduction I was told it takes 30 days this happened on 15 nov still not sorted,
on 29-12-2022 09:06 AM
Hi Lucianneiona0
Just to confirm, has the fault been resolved?
on 28-12-2022 03:23 PM
Whether or not you are eligible for compensation depends on a number of factors. You have to understand that TalkTalk have 2 working days after you report the fault to get it fixed, for example. You should get compensation for any extra working days after that. It's all explained here: About your auto compensation credit - TalkTalk Help & Support
If you would like TalkTalk staff on this forum to help, it's best to make sure your forum profile is updated with your personal details and your TalkTalk landline number in order that they are able to find your account (don't post personal details on the thread though).
