Broken stand on Wifi Hub
9 REPLIES 9
New Wifi Hub, 5 minutes old. Stand will not reattach, severed limb. Please send a replacement, thanks.
Can you please add your home phone number to your Community Profile so I can locate your details.
If unsure of your number, simply dial 17070 from your land line phone and this will confirm the number for you.
Please reply when this has been updated.
Hi Karl,
Thanks for the update, I have updated my details.
Hi lsbills,
Thanks for updating your details, can I just ask where you got the wi-fi hub from?
Hi Chris,
Yes, I ordered it straight from Talktalk, please check my account for the details, thanks.
lsbills
Hi lsbills,
Thanks for the information, did you order from the TalkTalk online store? If you did then you'll need to return the router via their returns process, I'm sorry for any inconvenience
Hi Chris,
No it was ordered through customer services after finding a fault in my previous router. My situation is not any different to https://community.talktalk.co.uk/t5/Fibre-Broadband/Broken-stand-on-Wifi-Hub/td-p/2281858. I have spoken to customer services but they keep asking me if my Wifi i down or not, pretty useless.
lsbills
Hi lsbills,
So that we can look into this further I've sent you a PM to confirm some other details
Hi lsbills,
I've replied to your PM
