Cannot use WiFi with Cisco VPN
9 REPLIES 9
Hello, my talktalk WiFi works for all my devices except for my work laptop when I try to connect to the internet via Cisco VPN. Please can this be fixed ASAP? My router number is DSL-3782. Thank you.
You first need the router upgraded to V1.10 firmware & for the Cisco client, it is best that you use the Google DNS servers in the router's internet configuration:-
8.8.8.8
8.8.4.4
Replacing the standard TalkTalk ones.
I have asked one of TalkTalk's OCEs to pick your thread up and upgrade the firmware as well as hopefully setup the DNS servers at the same time for you.
Hi lswerica,
As Keith has said, you need the latest firmware version. Can you please update your community profile to include your:
  • Name
  • Telephone number
  • Alternative contact number
Thank you very much for all your help, I have updated my profile accordingly. I really appreciate it 🙂
Hi lswerica,
  • TalkTalk Telephone number
Thanks, I have updated my profile accordingly. Hopefully this can be fixed soon because this has been a huge hassle - I’ve not been able to even send basic emails from my laptop. Please keep me posted, thank you!
Hi lswerica
Thanks for updating your Community Profile. I've checked and I can see that your router has the latest firmware version so this should work ok with VPN.
Please can you try factory resetting your router using the pin hole reset for ten seconds and retest? If you are still experiencing this issue following this then we can send a replacement HG633 router for testing.
Hi, I’ve reset the router but the problem persists. Please can you help me - thanks!
Thanks the issue has now been fixed after I changed the routers MTU
Hi lswerica,
Thanks for the update 🙂
