Certain apps are not connecting properly through wifi.
3 REPLIES 3
Zitamac
Thos is driving me crazy! Facebook and other apps will not refresh or connect properly. They work fine on 4g. Because I keep using my data up I can't even use a system I thought would work! Tried doing the refresh, uninstall app and refresh router. No good 😨
OCE_Debbie
Hi Zitamac
Please can you log into My Account and check if HomeSafe/KidsSafe is switched on? If this is on then try switching this off to see if it resolves this issue?
Zitamac
Yea it seems to be working!!!!! Thankyou 😉
OCE_Debbie
Hi Zitamac
That's great, thanks for keeping us updated 🙂
