Change DNS settings on router
Huzaifa
Message 6 of 6
Hello, I have a couple of questions about the default provided router, TalkTalk Wi-Fi Hub.
Hardware Version: FAST5364 3.00
Software Version: SG4K10002816t
GUI Version: 3.7.8
It seems the interface will not allow me to change the default DNS settings. How does one go about changing the DNS settings on the router?
Also, does the router automatically update the firmware and user interface versions or do I have to manually update them myself, and if so, where do I download the necessary files?
Thanks in advance.
5 REPLIES 5
ifanyonecan
Whizz Kid
Message 1 of 6
I changed it in internet connectivity!!
Mark
Message 2 of 6
  • Name
  • Telephone number
  • Alternative contact number
Skynet_TX
Message 3 of 6
Have you tried in a different browser, just to see if it is browser related, that screen in the router settings certainly works fine for me (Chrome on Windows 10).
If it is looking like there might be a problem with your router and you would like some help from the staff here you will need to update your community profile to include your name, landline telephone number that your TalkTalk service is provided on & an alternative contact number. This will allow them to identify you, and they will then be able to help.
Huzaifa
Message 4 of 6
I presumed, "the interface will not allow me to change the default DNS settings", would be clear enough but apparently not. So, to clarify, the input boxes under the DNS Tab are disabled and will not accept any input. Yes, "Make sure ON is enabled", I have. Also, the usual "Apply" button is also missing. I checked the HTML comments, it seems it's been removed on purpose, hence why I'm posting here.
PS: I already checked that link before posting here.
Thanks for replying.
Skynet_TX
Message 5 of 6
Hi @Huzaifa,
There are details on how to change your DNS settings here.
Firmware will auto update overnight when necessary, you can't download firmware updates to apply them yourself.
You are currently on the latest firmware.
