Cisco VPN Router not connecting
6 REPLIES 6
I have moved to TalkTalk today and in the process of connecting all my devices. I use a Cisco Access Point (AIR-OEAP602I-E-K9) for VPN access and telephone calls to my work network. I have connected this to the router and it is not working. The Cisco Access Point is wired and other devices that are wired to the TalkTalk router are working fine. What do I need to change in order to get the Cisco Access Point working.
What make/model of router were you supplied with?
Hi sumner1985
Apologies for the delay.
Just to confirm, which router are you using? (make and model)
Sorry for the delay. It is the talktalk wifi hub. I cannot see any model number or reference on the router.
Hi sumner1985
The WiFi Hub should work ok with VPN. Have you tried factory resetting the router using the pin hole reset for ten seconds?
Are you able to connect wired?
Hi Debbie,
After the reset, it seems to be working. Thanks for your help.
Hi sumner1985
That's great, please let us know if you do experience any further issues.
