Configure static IP for a device on the netwrok
jcgordon
Message 2 of 2
Hi there,
I'm trying to assign a static IP address to one of my devices so that I can then select the port forwarding option. Currently the device is changing its IP frequently hence the port forwarding is not working. Where can I make a device's IP static? All I can see is the reserve IP button but that doesn't seem to work. Any help would be greatly appreciated! Thanks.
1 REPLY 1
martswain
Message 1 of 2
On the Huawei DG8041W HUB you need to go to advanced settings > LAN configuration > DHCP static IP configuration.
You need the device MAC address.
