Connecting 2 talktalk routers help
TexasPete
Message 11 of 11
Hello
I have the dsl-3782 in one room which I want to connect wired to Huawei hg633 to another room. I get internet on the first router but not on the other router. I have disabled dchp on the second one but I still can't internet connection and I don't know why. It was working beforehand but I stupidly reset the second one and now I can't get it to connect.
Any ideas please guys
Many thanks
10 REPLIES 10
Message 1 of 11
Looks like I jumped the gun a bit. Xbox won't connect to internet via lan to master. Also the laptops won't connect to the internet via wifi with any of the routers. Phones working ok though. Not sure what's happening. Master will work if I disconnect the lan to the slave but as soon as I reconnect the lan it plays up like I've mentioned
Message 2 of 11
Managed to get it working somehow. I switched on the slave with nothing connected and left it for 5 minutes then I plugged the lan into it and it started working. Big thanks for your help
Message 3 of 11
Spoiler
Doesn't fit anyway mate but thanks for the tip.
Message 4 of 11
OK, best of luck.
Also, the LAN cable into the "slave" needs to go into a LAN socket, not the Broadband/ADSL socket.
Message 5 of 11
Will try when I get home from work mate. Cheers
Message 6 of 11
Yeah the master is on 192.168.1.1 but still no luck
Message 7 of 11
What works for me is this.
Master Router IP 192.168.1.1
DHCP 192.168.1.100 to 192.168.1.200
Slave Router IP 192.168.1.2
DHCP disabled on slave
Both routers have IPs outside the DHCP range.
Message 8 of 11
As soon as I connect lan to lan it knocks the internet from my master unless I remove it.
Message 9 of 11
Yes connecting by lan. The master dchp is on a range of 198.168.1.1 to 198.168.1.50. The slave ip is 192.168.1.51. Still no connection to internet.
martswain
Message 10 of 11
Are you connecting the 2 routers LAN to LAN using the YELLOW sockets ?
Give the "slave" a fixed IP address outwith the range of the "master".
