Connection not private - Server certificate not trusted
17 REPLIES 17
Is anyone else having issues with connecting to websites, whereas it is stating the server certificate is not trusted? (even when trying to connect to the talktalk site). I am constantly getting the following message:Screen shot 2020-07-23 at 19.14.55.png
On trying to speak with a technical support agent at TalkTalk, I have been cut off 3 times and it does not seem they know what they are talking about?!
On further investigation into why the certificate is not trusted, it states this:Screen shot 2020-07-23 at 19.35.17.png
Anyone have any idea's or answers?
Hi @TJamesM ,
Sorry for checking the obvious, but is the time and date correct on your computer ?
Hi @Skynet_TX
i can confirm it is correct, first thing I checked
@TJamesM ,
This might have some interesting info : https://apple.stackexchange.com/questions/221297/this-certificate-was-signed-by-an-untrusted-issuer-...
Disclaimer : I know nothing about Apple products, so I don't know if the above will help or if it is a sensible / safe thing to try, but might be something worth at least having a look at for your top level USERTrust certificate.
Presumably where that article says to look for the 'Entrust' certificate, in your case you would want to check for the 'USERTrust' certificate
Hi TJamesM,
Does this happen on more than 1 device?
No just my desktop Mac
Hi TJamesM,
Ok thanks for confirming. @KeithFrench - Would you be able to offer any additional advice?
Hi @OCE_Michelle
No sorry, I can't help with Apple products as I do not have any. Try @ferguson as he has MACs etc.
Hi TJamesM,
Have you tried clearing the browser (cookies and cache)? Have you also tried a different browser?
Yes, I have tried both as well as ensuring the date and time is correct
Hi TJamesM,
The security certificate for the TalkTalk site is valid until 2021. We've also tried to replicate this on a imac we have here and we don't see this error message. If it works ok on different devices then it suggests a possible issue specific to this device.
As a Mac user I am not getting this issue.
@TJamesM Which version of macOS are you using?
10.6.8
Whoa, that's a bit old! Perhaps that's the problem?
It’s what I thought, but just seeing if it is for sure, as all other websites I go into (for example the BBC) are fine
Hmm, no real idea then I'm afraid. Does does this occur across multiple browsers?
Did you check the 'Keychain Access' application to see if there were any 'Root Certification Authority' certificates that had recently expired on your system that are related to that chain of certificates shown in your screenshot ?
From what I can see, no certificates have expired
