Connectivity issue
Bighammerfan
Message 11 of 11
Hi all. I have a problem were my broadband works but some things wont connect. I have cctv which is connected to the router via ethernet and i can watch that remotely. I also have several smart plugs which haved worked for a long time but now say 'offline' unless i connect to my home wifi that they are on then they work. I also have a  and a Honeywell wireless room thermostat which connects to the boiler wirelessly but, again, on my phone now says 'offline' and connecting to the home wifi doe no good.  Any help would be gratefully recieved.
Alan
10 REPLIES 10
Message 1 of 11
Hi Alan
Please let us know how the connection compares with the replacement router.
Debbie 🙂
Message 2 of 11
No problem thank you
Alan
Message 3 of 11
Hi Bighammerfan
Apologies, It appears that Karl had already placed the router order so this will go to your home address.
Bighammerfan
Message 4 of 11
I also meant to say my sky mini box wont connect to my Sky Q box which works fine
Message 5 of 11
Hi could you send it to my work address please ?
Message 6 of 11
I'll get the other model Hub out to you and see if this improves the wifi connection to your devices.
Message 7 of 11
I certainly haven't changed this myself
Divsec
Message 8 of 11
Sorry @Bighammerfan ssid is the name of your WiFi The abbreviation SSID stands for Service Set Identifier. This is the unique name that identifies a wireless network. It is in the packet header when a data packet is transmitted. The devices on the Wi-Fi network use this identifier for communications via the network.
Message 9 of 11
Hi. Thanks for the reply. No i haven't changed it and not reset it to my knowledge. What is SSID ?
Divsec
Message 10 of 11
Hi @Bighammerfan have you by any chance changed your router or reset it? If somehow the ssid has changed this would explain (I had this recently)
Your post has been flagged for assistance and you should hear soon but please remember that the staff here work office hours.
