Constant disconnects every 10 minutes, had engineer out end of last year, started again.
Akimbo
Message 3 of 3
Pretty tired of connection issues with TalkTalk. Connection drops 10-20 times a day for anything between 2-5 minutes at a time. Had two engineers out towards the end of last year, one bt, one connection.
Problem seemed to be finally solved and my connection was (relatively) stable.
Now I'm back to disconnecting as above. All. The. Time.
The moment the weather becomes damp? No Internet.
Wind blows? No Internet.
No reason? No Internet.
No phone is connected to the socket. Last time I did for the engineer the line was awful.
Router is new from last time this happened.
Really sick of this now as I don't want to spend hours and hours going back and forth with TalkTalk to solve a problem that shouldn't exist.
Message 1 of 3
Hi Akimbo,
I'm really sorry to hear this and I'll take a look now. I've run a test on the line which hasn't detected a fault, however the connection does look very unstable. Would it be possible to connect a phone to the line to see if there is a dial tone/any noise on the line as a voice fault can affect the broadband connection?
Message 2 of 3
