D L M
21 REPLIES 21
Chat Champion
Hi - It looks like DLM has been at again, always dropping speed but never taking it back up.
My speeds are now slower than promised (and that was slooooow to start with!)  having rebooted the router the stats show a Maximum Rate of 2,844kbps but I have an Actual Rate of 1,020kbps, could you please reset my profile.
Hi MarkW,
I'm sorry to hear this. I've optimised the connection as requested. Please let us know how the speed compares now.
Chat Champion
Thanks for that.  Router now reporting:-
Down Max  2,748   Actual  2,045
Up      Max     952   Actual     952
Strange how the Up speed is always at or near the maximum router sync speed but the Down speed seems to have a 'brake' on it.
Hi MarkW,
Thanks for the update. It's possible that DLM may increase the speed over the next 24hrs now that DLM has been reset.
Chat Champion
DLM increase speed.....now that would be a 1st...!
Hi MarkW,
Could you bump the thread tomorrow and we'll see how you're getting on
Chat Champion
Last November I started a topic thread 'Back on the Merry-GoRound'.  I revisited the thread again in April and here I am again with exactly the same problem.  Groundhog Day.
Router stats after DLM ran earlier this morning
Down Max Rate 2,732  Actual 1,531
Up      Max Rate   972  Actual    763
Hi MarkW
There are a high number of errors showing on the line. DLM wont increase the speed if the connection is unstable or if there are a high number of errors.
Just to confirm, is your router currently connected at the test socket? Have you tested with a different router?
Chat Champion
I give in.....someone take me out and shoot me.
Chat Champion
My router is now showing a sync rate of 2,924Kbps but an actual rate of only 761Kbps!  I have been here so many times before an OpenReach engineer will visit declare the line good for 2 / 2.5Mbps and the whole circus starts again.  How can a router sync at nearly 3Mbps but TalkTalk supply a service significantly less?
Hi Mark,
DLM has moved you to a slower profile but your SNR is also low which indicates increased noise on the line
How many telephone sockets do you have? What other devices do you have connected in addition to your router?
Does your master socket have a Test Socket?
Chat Champion
The Openreach MK4 master socket is connected to the router less than 1ft away and a DECT phone base station there are no wired extensions. The master socket has a test socket.  The WiFi performance is not a problem the speed difference between wireless connection and wired Ethernet connection is negligible.
Thanks. Could you disconnect the phone and then reboot the router and let me know when you've done this. You won't see a speed increase but I'll check if this makes any difference to your SNR
Chat Champion
All done.
OK thanks, I'll take a look at this now 🙂
SNR is a bit better but not really as high as it should be.
Could you connect the router directly to the test socket and I'll check again to see if there's any improvement
Chat Champion
All done.
Thanks. SNR has again increased a bit - do you have another router you can test with?
Chat Champion
Yes - now plugged in via the test socket.
Thanks Mark,
The SNR has improved again so I've arranged for optimisation to start again tonight to see if we can get it to settle on a faster speed. Can you leave the router connected to the test socket for the time being and bump the thread again on Friday and we'll see how it's getting on
