D-Link DSL 3782 VPN not working?
HydeTDS
Whizz Kid
Message 15 of 15
Hi, I have 2 other threads on this forum since receiving my new router from TalkTalk. Both very annoying, but not show stoppers.
However, I've just tried a VPN connection, something my employer insists on, and I can't get a connection to the Web.  I see other posts from around a year ago saying this is an issue but surely its been fixed by now? Or is this still a problem? If it is, I see little reason to stay with TalkTalk after 10+ years as a customer. If I'm to buy my own modem / router, I may as well switch providers too!
14 REPLIES 14
Message 1 of 15
Hi @EB2811
Can I also just confirm which VPN client you are using?
Message 2 of 15
Hi @@EB2811
Could you reboot the router and try this again?
If you are still experiencing this issue then I can send a replacement router for testing.
Message 3 of 15
I have done this, it worked yesterday and tried to log in today and it won’t work again..
Message 4 of 15
Hi @EB2811
Thank you for updating your Community Profile.
Your router has the latest firmware version. Have you tried splitting the SSID's?
You could try splitting the SSIDs on your router and testing the connection between the 5gh channel and the 2gh channel, some devices operate better with just 1 channel selected.
Log into the router  (192.168.1.1 etc ) and manually change the SSID (Wi Fi) name of the 5ghz channel.
I often find it is better to keep the 2 broadcast channels separate.  For example, I have changed mine, and call one Home2Ghz and the other Home5Ghz.  Some devices can drop the connection when the SSID's remain the same.
Also, you can try manually setting the wifi channel  for each broadcast channel. Try channel 6 for the 2ghz channel and 44 for the 5ghz channel.
Give this a try , test with both SSID's and see if the connection improves.
Message 5 of 15
I have updated my talk talk telephone number but I do not have a landline phone connected at this time, so my mobile number is there too .. thank you
Message 6 of 15
Hi @EB2811
Is the telephone number in your Community Profile your TalkTalk telephone number? (please do not post the number on this thread)
Message 7 of 15
Hi Debbie,
I have updated this info
i look forward to hearing from you
Many Thanks
Message 8 of 15
Hi @EB2811
  • Name
  • Telephone number
  • Alternative contact number
Message 9 of 15
Hi HydeTDS
EB2811
Message 10 of 15
Apologies to jump on this post, however i am having the exact same issue with my router DSL3782 connecting my VPN-  I really need to be able to work from home,is there anyway of fixing this issue? i did try and start my own thread however the website failed me!!
Many thanks in advance
Message 11 of 15
Hi, it is running the version 1.10t and my issue with VPN has gone away. Not sure why, but please it has.  No further action required in this respect.  Many thanks.
Message 12 of 15
Many thanks for the kind offer but for some reason the VPN connection just started working again.  So no issues in this respect now.  Cheers.
Chris-TalkTalk
Message 13 of 15
 Hi HydeTDS,
I can send you another router to test with, would you like me to arrange this?
Message 14 of 15
If the router is running firmware V1.10 this should now be OK, unless you are using a Cisco VPN client. If you are, the normal practice seems to be to swap it out for an HG633, which will work OK.
