DG8041W Router Kernel Panic Random Restarts
aarong_96
Message 4 of 4
Good Evening,
Over the last couple of weeks, my router is experiencing random restarts (confirmed by uptime following restart) and upon checking the user logs following the restart. Cause seems to be due to a system Reser due to a kernel panic. No idea what is causing this, however I have noticed in other older threads that a software update was developed to resolve this issue. My router is currently on version v1.05t, there doesn't seem to be a way of self serving & acquiring the update file,
Can anyone confirm what the latest version should be & where I can get hold of a software update / fix for the issue?
Extract from user log for reference -
1981-01-01 00:00:10 [Error][Alarm-Log] AlarmID:104001,AlarmLevel:Error,Device reset. Cause: System reset due to kernel panic, Terminal:OTHER
Thanks,
Aaron
3 REPLIES 3
Message 1 of 4
No problem, just let us know if you need any further assistance
Message 2 of 4
Great, thank you!
Message 3 of 4
Hi Aaron,
i've updated the router and this should be ok now.
