DLM reset - ADSL2+
tomuk5
Message 3 of 3
had a few problems with my line recently (lightning strike) that are now resolved but i have a poor line profile applied 500kbit on a 5mbit sync, please can an OCE do a DLM reset?
Controller VDSL 0 is UP
Daemon Status:           Up
                        XTU-R (DS)              XTU-C (US)
Chip Vendor ID:         'BDCM'                   'IFTN'
Chip Vendor Specific:   0x0000                   0x71C8
Chip Vendor Country:    0xB500                   0xB500
Modem Vendor ID:        'CSCO'                   '    '
Modem Vendor Specific:  0x4602                   0x0000
Modem Vendor Country:   0xB500                   0x0000
Serial Number Near:    xxxxxxxxxxx C897VA-K 15.7(3)M4a
Serial Number Far:
Modem Version Near:    15.7(3)M4a
Modem Version Far:     0x71c8
Modem Status:            TC Sync (Showtime!)
DSL Config Mode:         ADSL2+
Trained Mode:   G.992.5 (ADSL2+) Annex A
TC Mode:                 ATM
Selftest Result:         0x00
DELT configuration:      disabled
DELT state:              not running
Full inits:             13
Failed full inits:      33
Short inits:            31
Failed short inits:     3
Firmware        Source          File Name
VDSL            embedded        VDSL_LINUX_DEV_01212008
Modem FW  Version:      4.14L.04A
Modem PHY Version:      A2pv6C039t.d24o_rc1
Trellis:                 ON                       ON
SRA:                     enabled                 enabled
 SRA count:              10                      5
Bit swap:                enabled                 enabled
 Bit swap count:         7                       0
Line Attenuation:        55.0 dB                 31.8 dB
Signal Attenuation:      55.3 dB                 32.0 dB
Noise Margin:             6.3 dB                 23.1 dB
Attainable Rate:        5000 kbits/s             820 kbits/s
Actual Power:             0.0 dBm                12.8 dBm
Total FECC:             582017                   12221
Total ES:               1200                     14
Total SES:              131                      0
Total LOSS:             16                       0
Total UAS:              4314                     4219
Total LPRS:             0                        0
Total LOFS:             89                       0
Total LOLS:             0                        0
                  DS Channel1     DS Channel0   US Channel1       US Channel0
Speed (kbps):             0              505             0               251
SRA Previous Speed:       0              508             0               251
Total Cells:              0            26010             0              9849
User Cells:               0               22             0                39
Reed-Solomon EC:          0               10             0                 0
CRC Errors:               0             6724             0                63
Header Errors:            0                0             0                 0
Interleave (ms):       0.00            15.00          0.00              7.89
Actual INP:            0.00            26.67          0.00              1.75
Training Log :  Stopped
Training Log Filename : flash:/VDSLLOG.txt
Thanks!
Message 1 of 3
Hi tom,
I'm sorry to hear this. I've run a test on the line which is detecting a possible fault towards the property. Does your master socket have a test socket? If it does then would it be possible to connect the router directly at the test socket so we can re-run the line test again and also so we can optimise the connection in this set up?
Gliwmaeden2
Message 2 of 3
Staff will be back on here from Monday,  @tomuk5.
